33
Discussion topic: Sky remote code for LG tvs
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Sky remote code for LG tvs
@Greytop wrote:
I have the same problem. I have tried numerous codes and LG support and Sky support are no help at all.
Use the procedure given on this post https://helpforum.sky.com/t5/Sky/code-for-remote/m-p/3073017#M88271
This message was authored by Jord135 This message was authored by: Jord135
LG Sky Remote
I've just received a new Sky + remote and I won't let me connect the remote to the tv.
I have an LG - 42LA690V.
None of the sky remote codes work and my tv make & model isn't registered on the sky website.
PLEASE HELP!!
Re: LG Sky Remote
Give this a try:
If it works you can then have the remote tell you what the code is by doing this if you want to write it down somewhere:
Press TV,
Hold Select and red together until the red light at the top of the Sky remote flashes twice.
Press 990, and the LED at the top of the remote blinks twice.
Press 1, take note of the number of red LED blinks, as this indicates the first digit of the code.
Press 2, take note of the number of red LED blinks, as this indicates the second digit of the code
Press 3, take note of the number of red LED blinks, as this indicates the third digit of the code
Press 4, take note of the number of red LED blinks, as this indicates the fourth digit of the code.
(0 is represented by no blinks when you press the key.)
This message was authored by jim8sky This message was authored by: jim8sky
Re: LG Sky Remote
Did you have a remote that did work?
If yes open the battery cover and look at the revision no on the label.
Your new remote may well be a newer version which may not work with older TVs
This message was authored by lynztam This message was authored by: lynztam
this code worked for me, thanks! ive tried all the others and nothing had worked
This message was authored by Yafflebag This message was authored by: Yafflebag
https://www.sky.com/help/program-your-remote
I found this easy to use to help in case anyone else struggles in future.
This message was authored by Kovos This message was authored by: Kovos
Don't press TV button after holding down select and red button, just input tv code. Some manuals tell you to press TV button again in step 4 but just skip this.
This message was authored by adgta This message was authored by: adgta
Re: LG Sky Remote
The blink back procedure worked, but the code itself didn't work.
My LG is also not on the Sky site (43UN81), where do I go from there?
This message was authored by warriorfan This message was authored by: warriorfan
Re: LG Sky Remote
try 1868    2210   1451 1333  1280  1665  1755 i know one of these worked for me with a LG tv and a new sky remote
Re: LG Sky Remote
Thanks for the reply. I found a generic LG code online yesterday, 0206. That worked for me. Appreciate your help though.
This message was authored by AESB This message was authored by: AESB
Re: LG Sky Remote
Hi, I have a new LG TV but my sky Q remote wont pair with it I tried all the numbers but no luck.....
This message was authored by Mark39 This message was authored by: Mark39
Re: LG Sky Remote
I'd recommend posting in the Sky Q forum: https://helpforum.sky.com/t5/Sky-Q/bd-p/skyq
This message was authored by atherlon This message was authored by: atherlon
Re: LG Sky Remote
With the latest remotes
press tv
press red and select
DO NOT PRESS TV AGAIN
put in the code
press the "on" button
I tryed for ages to program a new remote to my lg tv and no code worked , then I found one post that said don't both pressing tv a second time and like magic code went straight in
This message was authored by hazdriver This message was authored by: hazdriver
This worked a treat with my 50up81006lr
This message was authored by Nannie+cat This message was authored by: Nannie+cat
Its 0000
On average, new discussions are replied to by our users within 100 minutes
