Discussion topic: Siting a sky box in the loft of a bungalow
Message posted on 10 Nov 2024 02:59 PM
We are moving to a bungalow that currently does not have Sky. We would like to know if it would be possible to put the Sky Box in the loft and bring the cables down to a wall mounted tv below?
Are Sky engineers happy to install a Sky box in a boarded loft with power?
How many cables would we have to run to the power source in the loft - one for the tv plus how many for the Sky box - are there any other issues to bear in mind?
Message posted on 10 Nov 2024 03:04 PM
Re: Siting a sky box in the loft of a bungalow
Sky engineers will definitely not go into a loft boarded or otherwise. Their H & S policy in very strict.
Message posted on 10 Nov 2024 03:06 PM - last edited: 10 Nov 2024 03:06 PM
Sky no longer supply/install Sky Plus
Message posted on 10 Nov 2024 03:07 PM
What Sky TV service, if any, do you currently have?
Message posted on 10 Nov 2024 03:31 PM
Sky Q 1TB Box
Could the box be placed behind the wall mounted tv?
Message posted on 10 Nov 2024 03:37 PM
A Sky+ box would be a bit big for that?
Message posted on 10 Nov 2024 03:38 PM
Message posted on 10 Nov 2024 03:39 PM
@DM21 wrote:Could the box be placed behind the wall mounted tv?
It depends on what type of Sky box you are planning on having.
A Sky Q box is quite big and needs a lot of space around it to prevent overheating so would need to be in a large, well ventilated alcove if you wanted to place it behind a TV. It would also need the cabling from the satellite dish to be fed to that alcove which may well be beyond the scope of a Sky engineer.
A Sky Stream puck is a lot smaller and can be placed behind a wall mounted TV, but it is not recommended. It also needs some ventilation and needs to be able to receive a fast and stable broadband signal in order to function. Being placed behind a TV doesn't exactly allow this to happen easily, unless you opt for an ethernet connection - but that's another cable.
Message posted on 10 Nov 2024 03:42 PM
I agree. Panel TVs are pretty good at obstructing wifi.
