Discussion topic: Sky plus
This message was authored by: kacie.x
Sky plus
Input 1 in white Input 2 not white on sky plus
Re: Sky plus
This indcates an issue with the connection from the dish either the socket on the box, the cable or the LNB on the dish
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Re: Sky plus
It means you have no signal from the dish reaching dish input 2. You could try turning your Sky box off at the plug and checking that the dish connections at the rear of the box are securely fitted and finger tight.
Avatar for kacie.x
Re: Sky plus
And cn this make my picture on tv look dark
Re: Sky plus
Turning your Sky box off and on or tightening the cables should not affect your TV brightness
