Discussion topic: Reception issue
This message was authored by: MarkDaly
Reception issue
I want to speak with someone in relation to a reception issue I am having with my plus HD box.
Re: Reception issue
@MarkDaly  As Sky no longer support Sky+HD boxes you will either need to arraneg your own installer to check your dish or upgrade to Sky Q
They won't come out for Sky+HD box issues.
Re: Reception issue
What sort of reception issue? You can always call Sky, but their first response will be Sky+ is obsolete and you need to upgrade.
Avatar for MarkDaly
Re: Reception issue
I cannot find the contact number for Sky. Does anyone know the contact number?
Re: Reception issue
You can find the number via the 'need more help' link here: https://www.sky.com/help/home
Re: Reception issue
@MarkDaly
As you seem to be pursuing calling SKY then I think you may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
As they are only likely to sugesst you upgrade to SKY Q (or Glass/Strea,=m)
This message was authored by: Maria104
Re: Reception issue
Mine still works fine just started the other day with signal issues now I can't watch anything and I've had sky + for 9 years
Re: Reception issue
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
