Discussion topic: Sky plus old box
This message was authored by: Simon+Krish
Sky plus old box
Guys have a old sky plus box , but cant watch anything as it says satilite signal not working.
but oddly can record the channel.
this has been going like this a good while. Usally with bad wearther it dont work, but now seems stuck ?
any thoughts . Have reset a couple of times, and unplugged and reset etc. IMG_8279.jpeg
Re: Sky plus old box
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Avatar for Simon+Krish
Thanks for the info , theres a lot there to digest thats for sure , which check the box cables , cant get on the roof to check, oddly can all come back on in a few days time, thats why i tend to always blames the weather , and not crafy Sky trying to get me to up grade . S
@Simon+Krish it's not of Sky's doing. Possibly rain is getting into the dish cables causing the loss of signal. When the cables dry out the signal returns.
Cheers . Am trying my best not to climb up and mess with the dish, i have the aligmnet gauage , will see in a couple of day.
