Discussion topic: Sky plus desd
This message was authored by: .Mike-.
Sky plus desd
I have 2 sky plus boxes in different rooms the one in the kitchen is showing a programme with only one sat feed working. The other sky plus box shows no signal on both feeds. Last night I was getting sound and pictures either only one sat feed showing as live. Tonight both sat feeds are shown as no signal,
Re: Sky plus desd
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
