Discussion topic: Sky plus box not working
This message was authored by: Aneela1
Sky plus box is not working
Re: Sky plus box not working
@Aneela1  In what way? We need more information like error messages on screen if we're to help
This message was authored by: CCowley
My sky +box is say not getting a signal
You mean no satellite signal?
Try restarting your Sky box by switching off at the plug for 4 minutes.  If that doesn't resolve it, the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
It says your sky + box is not getting a satellite signal
See my previous reply.
