Discussion topic: Sky+ playback is not available. No recordings possible.
Message posted on 17 Nov 2023 10:43 AM
Hi. One week ago, we lost the ability to watch anything on our planner, and recording stopped recording.
I did a software update - this hgave better experience, but the planner and recordings was the same message.
Planner rebuild - did not work.
We have not ordered SKY Q. We are just a very baisc Sky customer.
Any further ideas form anyone?
Message posted on 17 Nov 2023 10:54 AM
Re: Sky+ playback is not available. No recordings possible.
When you tried the Planner Rebuild, did you get a 'diskless mode' error? If so, it looks like the hard disk has failed which means the box will need to be replaced.
Message posted on 17 Nov 2023 10:57 AM
Hi . No, I didn't. No messages at all, so I was hopeful / confident it would work. But same issue. I suspect my last resort is a full system reset, where I lose current recordings. But if there was any other final trick...
Message posted on 17 Nov 2023 11:07 AM
I'd give a Planner Rebuild another go first. Failing that, yes, I'm afraid the next step would be a full System Reset.
Message posted on 17 Nov 2023 11:10 AM
thank you. i did it twice. thrid time lucky then the nucleur option.
cheers
Message posted on 18 Nov 2023 10:52 AM
Hi. Could you confirm the steps to the best / most comprehensive full system reset? Thanks
Message posted on 18 Nov 2023 11:35 AM
Yes, the System Reset option from the same menu as the Planner Rebuild will do that. If it doesn't help let us know.
Message posted on 18 Nov 2023 01:26 PM
Thank you. That hasn't worked, and I have also reset via the hidden menu. That has cleared my planner, but I cannot record / pause/ schedule recordings
Could it be because I am not a Sky customer? I have the box from when I did subscribe. I don't anymore. But the box has worked properly for years, since I subscribed and since I stopped Iopped.
Message posted on 18 Nov 2023 01:37 PM
It's certainly a possibility. The recording/playback features are a paid-for add on - usually free when you have a TV subscription. It's very unusual, however, to have them indefinitely once you've cancelled. There used to be a stand alone Sky Plus subscription specifically for recording and playback only but I'm not sure that it's available any more. It's possible that Sky has finally have caught up with you and disabled the feature on your box!
