Discussion topic: Sky pin number
Message posted on 18 Dec 2022 07:20 PM
Sky pin number
Just purchased used sky+hd box c/w card but some channels asking for pin number. Tried last 4 digits of card that came with box but sky keep telling me pin is incorrect. I cannot change pin number online as I have no sky account. I cancelled mu account 6 years ago when made redundant When mt sky box broke down it was cheaper buying used box than repairing broken one so it went in the council recycling skip but I forgot to keep existing card.
How do you find pin number of card that I now own? I have lost the sellers details so cannot contact them
Message posted on 18 Dec 2022 07:23 PM
Re: Sky pin number
@protonman You can't use a second hand viewing card as it's against sky's terms and conditions
the seller had no legal right to give you the card as it's sky's property which is not transferable
Message posted on 18 Dec 2022 07:30 PM
Re: Sky pin number
doesn't answer my question
Message posted on 18 Dec 2022 07:31 PM
Re: Sky pin number
If you are planning to use this box as a freesat one then you will need to call Sky to see if they will let you have a new card, but from memory you only need it for a few of the free channels anyway as most you can view without a card.
Message posted on 19 Dec 2022 08:37 AM
Re: Sky pin number
Your question is irrelevant as you have no right to use the Card.
Message posted on 19 Dec 2022 10:28 AM - last edited: 19 Dec 2022 10:52 AM
Re: Sky pin number
Without a Sky subscription you have no legitimate access to any channels which apply Mandatory Daytime Protection: no free-to-air service does so because they do not broadcast post-watershed content in daytime hours.
As purchaser of second-hand Sky+ hardware you can use it for Freesat reception only: a previous owner misguidedly leaving their viewing card in the box doesn't change this.
