Discussion topic: Sky not working
This message was authored by: TessiesBar
Sky not working
Sky signal not working for tv
Re: Sky not working
@TessiesBar
Are you seeing a no satellite signal message ?
This message was authored by: Tommy2
Re: Sky not working
What message are you getting on the screen ? are you able to provdie some more detail please.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
Re: Sky not working
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/.or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
