Discussion topic: Sky not working
Message posted on 03 Nov 2025 07:23 PM
Sky not working
Says I need to upgrade to sky, been with sky 20 years
Message posted on 03 Nov 2025 07:25 PM
Re: Sky not working
This happens about once a fortnight then I contact sky they ask loads of questions, which are irrelevant then send a signal? Then it works!!!! For another 2 weeks 🤷♂️😡
Message posted on 03 Nov 2025 07:43 PM
Re: Sky not working
As Sky+ (where you've posted) is a legacy product no longer supported by Sky the agents will be very limited in what they can advise you or be able to do remotely.
Now might be an appropriate time to upgrade to Sky Q or switch to Stream or Sky Glass.
Message posted on 03 Nov 2025 08:08 PM
Re: Sky not working
WE've seen a few posts here reporting the same. No idea why it happens to only some subscribers. Short of upgrading, you'll have to contact Sky every time, it seems.
Message posted on 03 Nov 2025 08:12 PM
Re: Sky not working
