07 Nov 2022 09:52 AM
We run our Sky+ box wirelessly with our 4G router from 3 as no other internet works out where we stay. Although it takes ages to download, it always gets there in the end.
For the past week however no matter what I attempt to download it will run to up to 14% then crash and show "failed" or "scheduled" and will just loop constantly round the things I'm trying to download to no avail.
To try to remedy this I connected the box to the WiFi by Ethernet to see if this would help but no difference at all.
I have disconnected every connection to the box and left it unplugged for 30 mins, reconnected it all but still the same thing happened.
I then did a system reset through the settings and cleared everything in my planner, downloads, scheduled etc hoping starting from scratch would fix it but it didn't and all I did was lose all the stuff in my planner.
Im at a loss now. Can't help but be suspicious that this started around the time I got a text from Sky asking me if I wanted to upgrade and to call them to discuss...
any help greatly appreciated!
thanks
07 Nov 2022 10:04 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you checked that these failed downloads are not in your deleted folder because if they are they will not deleting from there as well before you can try again to download them.
07 Nov 2022 10:37 AM
Hi, yes I've checked this- there are no items in my planner at all as I did a system reset. Just checked the deleted folder again and there are no items there. I've got two different programmes trying to download and the box is just looping between the two of them- getting to 6/7% then moving to the next one with nothing ever downloading
07 Nov 2022 11:04 AM
Posted by a Superuser, not a Sky employee. Find out moreWhat's the error message if you highlight a failed download in your Planner and press 'i' on your remote? From previous posts this kind of error can be related to your broadband service provider, if that's not Sky.
07 Nov 2022 11:10 AM
I to was contacted recently about an upgrade. Since then I have not been able to download at the speed I should be able to, very suspicious.
07 Nov 2022 11:14 AM - last edited: 07 Nov 2022 11:16 AM
Coincidence. There are numerous unrelated factors that can affect your download speed.
07 Nov 2022 11:25 AM
Sure I agree, but nothing is impossible. Trying to get Sky to assist in not worth the effort I am afraid.
07 Nov 2022 11:28 AM
I did a system reset this morning so I don't have any failed messages anymore.
I'm currently trying to download two different episodes of two different shows and 1 is showing as downloading (as is usual before it fails) and one is scheduled. I'll check the error message as soon as I get another failed message. Sometimes it just says "part rec" but I'll check back later and see if there is a fail error. Thank you
07 Nov 2022 11:29 AM
I was confused about this. I didn't plan to upgrade but since then my box has not completed any downloads. We have had sky for 7 years and whilst our download speeds are exceptionally slow due to where we live I have never encountered these constant fail issues when downloading
07 Nov 2022 11:31 AM
I understand it may be coincidence but we have made no changes to our broadband provider (3 network) who we have used for many years. The only thing that I can say is that this happened after/ around the time I had the text from sky asking me if I wanted to upgrade.
08 Nov 2022 10:51 PM
I've had the exact same problem for a week or so now and I'm also using a 4G router on the 3 network. We've got decent download speeds (100mbps+) but still failing to download.
09 Nov 2022 07:34 AM
We have just decided to upgrade so I'm hoping this fixes it! I don't suppose you've had an upgrade offer recently? My downloads stopped working right after I got a text about an upgrade. I find the timing a touch coincidental
09 Nov 2022 07:52 AM - last edited: 09 Nov 2022 07:52 AM
There appears to be an issue with Sky On Demand and 3's 4G service. There are a number of posts on the same subject in the Sky Q forum.
I don't know whether the same issue extends to their fixed line broadband service too.
10 Nov 2022 12:08 PM
Change the DNS on the sky box to 1.1.1.1 this will fix it for the timebeing.
10 Nov 2022 02:03 PM
Worked. 👍
On average, new discussions are replied to by our users within 100 minutes
