Discussion topic: Sky is not working
This message was authored by: ChristieLange
Sky is not working
Hi Team,
Please can you send an engineer to fix my sky because when i turn on is not working.
Thank you very much for your help.
Kind regards Christie Lange,
Re: Sky is not working
@ChristieLange wrote:
Hi Team,
When i turn on my sky is not working
Hi @ChristieLange Sky no longer support Sky+HD Boxes so an engineer visit from them isn't possible. You would need to find a local satellite engineer to investigate and fix.  Or, if you describe in what way it isn't working, the forum may be able to help.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
@ChristieLange when you turn on your Sky box, does the power LED on the front panel change from red/amber to green? Is the power LED not lit at all?
