Discussion topic: Sky+hd not getting signal
This message was authored by: Ara3
Sky+HD not getting signal
Re: Sky+hd not getting signal
A no signal message is coming from your TV.
A no satellite signal is from your Sky box so if you have checked the cables into the back if it that they are in firmly then you would need to contact a local company to you to come out and check your set up as Sky no longer does this for Sky+ boxes.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Do you mean no satellite signal?
