Discussion topic: Sky hd box
This message was authored by: kellybridie
Sky hd box
I have been informed that my sky hd box will be switching off in 3 months, I can't have sky Q as I live in flats and share a communal aerial, I can't pass the credit check needed for sky glass and the pucks are useless as I need to be able to record, so basically as a sky member for over 15 years I'm obviously no longer good enough for them as they don't seem to give two hoots!!!!
Re: Sky hd box
If you have a Sky+HD box it will continue to operate normally for the foreseeable future. What exactly have you been informed of and by who?
Avatar for kellybridie
Re: Sky hd box
By sky customer service they told me that there will be no more updates being sent to my box as they are going to be obsolete
Re: Sky hd box
That is correct but as there have been no updates for a good few years then it will not mean they will stop working anytime soon...
Re: Sky hd box
How did Sky contact you tell you that?
Re: Sky hd box
  • Email
Re: Sky hd box
What sort of Sky Box is registered on your account?
