Discussion topic: Sky+hd box Hard Disc Drive Error
This message was authored by: pellatt111
Turned off Sky+ hd box at the plug on Sunday, when turned on Monday there was a message saying system error - hard disc drive problem. No access to recordings, can't record, catch up not available. Did all the system resets but still the same. Very slow turning channels, limited TV guide information.
I hooked up a spare Sky+ hd box and it was working fine...recording, catch up etc..
Turned box off Monday night and when turned back on Tuesday exactly the same issues as with previous box. Same error message, unable to record etc. Rather strange that two boxes have developed the same issue in 48 hours!!
Re: Sky+hd box Hard Disc Drive Error
Coincidence only, I'm afraid. All Sky+ boxes are old, and it's quite common for components to fail after switch on after being unused.
There's nothing Sky can do to cause a hard disk to fail, if that's what you're thinking!
@pellatt111 Out of interest, why are you switching off at the plug on a night? Constant powering off and on will only shorten the hard drives life.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for pellatt111
It's not turned off at the plug often..maybe once a month. The 2nd box was turned on for the first time in weeks and worked fine, then overnight it developed the same issue as the 1st box. Coincidence maybe...but 2 desperate boxes in 48 hours? Phoned sky and they immediately offered an upgrade to skyq at no extra cost.
Yep, Sky+ is an end of life product and they're keen to get customers to switch to Sky Q,, hence the free upgrade incentive.
Be aware that you can't swap back if you don't like it.
This message was authored by: DAREDEVIL69
Turn of sky hd box by the plug,when I turned it back on the next day.Hard disk drive coming up...
This message was authored by: Bob142
How do I fix my Sky+ disc error
Search my Sky Plus FAQ for "diskless mode"
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
