Discussion topic: Sky + hard drive failure
This message was authored by: Starlight51
Cannot record
All recordings have gone
Planner working at a snails pace
Unwatchable
Re: Sky + hard drive failure
@Starlight51 call Sky to upgrade. Your Sky+ box has had it.
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
This message was authored by: Tommy2
as @Annie+UK  said try a rebuild, it doesnt necessarily mean that your Sky Box has had it, however regardless it is worth pointing out that Sky + is now considered a legacy product and was replaced with Sky Q 10 years ago, I have Sky stream which appears to be the way forward, if your inetrnet speed allows it then I would strongly recommend looking into Sky stream.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
