Discussion topic: Hard disk drive
Message posted on 03 Jul 2026 09:55 AM
Hard disk drive
I am unable to record programs there is a message saying 'There is a problem with your hard disk drive'
Message posted on 03 Jul 2026 10:04 AM
Re: Hard disk drive
@Ann2200 you could try a Planmer Rebuild and a System Reset, as explained here: https://www.sky.com/help/sky-tv/sky-tv-plus/sky-plus-watching-sky-tv/sky-plus-recordings/articles/re...
However, it's likely that the hard disk has failed and you'll need to upgrade to either Sky Q or Stream. It's not possible to replace a Sky+ box. Alternatively if you really want to stay with Sky+ you could engage an electronics specialist to replace the hard disk.
