Discussion topic: Sky+had box
This message was authored by: Mark8567
Sky+had box
Can I still use my Sky +hd box if I don't have a Sky TV subscription .?
Re: Sky+had box
@Mark8567
Yes as you will continue to receive the free channels. You will be unable to record and pause etc.
Avatar for Mark8567
Re: Sky+had box
That's what I thought , however I am not getting a satellite signal
Re: Sky+had box
Was the dish used for Sky Q as the LNB on the dish will not be compatible with Sky+ and you will get No Satellite Signal
Avatar for Mark8567
Re: Sky+had box
Yes I had Sky Q
Re: Sky+had box
@Mark8567 wrote:
Yes I had Sky Q
That's your issue, you'll need the dishes LNB to either be downgraded to a Sky+ LNB or upgraded to a Hybrid LNB (This allows Sky Q & Sky+ boxes on the same dish)
Avatar for Mark8567
Re: Sky+had box
Ah , I will need an engineer then ?
Re: Sky+had box
With no Sky subscription you will need a 3rd party satellite installer or you could do it yourself if you know what you are doing 🙂
Avatar for Mark8567
Re: Sky+had box
So , any other Freesat box will also be incompatible?
Re: Sky+had box
Yes, a Freesat 4k (UHD) box is compatible with a Sky Q LNB, but they're more expensive.
Avatar for Mark8567
Re: Sky+had box
Can you buy Freeview boxes that don't require an aerial , ie , WiFi or ehernet connectivity ?
Re: Sky+had box
Freesat boxes require a dish, Freeview boxes require an aerial
I'm not sure if an Internet connection is mandatory but I would guess not
Re: Sky+had box
Freeview Play is the online variant.  Almost all Freeview hardware would want an aerial feed though.
Re: Sky+had box
No. Freeview boxes use a terrestrial tv signal which is broadcast from a local. TV transmitter.
Freesat boxes use a satellite signal broadcast from a satellite (actually several satellites) in space orbit around the earth.
There are streaming services available which require only a broadband connection, such as N.ow TV, but you have to pay a monthly subscription.
Avatar for Mark8567
Re: Sky+had box
Ok , thank you so much , you have been extremely helpful . Have a good day .
