Discussion topic: Sky catchup unusable
Message posted on 25 Sep 2025 03:54 PM
							Re: Sky catchup unusable
Oh right. How did you read it?
Message posted on 25 Sep 2025 03:55 PM
I just reread it and see what you mean. I'm gonna just leave it for now as I don't feel confident enough. Of course it's up to everyone else what they choose to do
Message posted on 25 Sep 2025 03:56 PM
Go to settings - network - press down - press green- press down to DNS - press left to delete all the numbers - press 1 - press right - 0 - right - 0 - right - 1 - press green
This worked for me, I think Annie said 1.1.1.1 is an alternative setting
I'm sky+ / talk talk and it's worked for me
Hope this helps
Message posted on 25 Sep 2025 04:14 PM
							Re: Unable to download programmes
I have just experienced failure with downloading the X-Files series after getting to S4 EP10 with no problems at all. Now I have noticed that the scheduler states "DOWNLOADING" but the red light is not coming on and after about a minute the message appears "Broadband connection not detected please ensure that your Broadband router is connected to a phone line".
I still have a Sky +HD box and have had a few lock-ups but relatively it has served me well for many years. I check Services page and Network tab to see that Broadband connection is OK and also connection to On-Demand is OK.
I was on the phone to Talktalk for about an hour last night and eventually gave up because they thought I had a talktalk box but it's only their router, my line has been affirmed as OK with no faults on it.
I have powered down and unplugged everything in the right order to what I have read on the internet but this has not affected the problem. I have eliminated the "wireless" connectivity by connecting the two via Ethernet cable but the same fault persists. I want to avoid a complete reset of the box as I have saved programs on here that I do not want to loose.
Any help appreciated?
Thanks.
Message posted on 25 Sep 2025 04:16 PM
							Problems downloading programmes
Problems downloading programmes. Can't download catch up tv or film trailers etc
Message posted on 25 Sep 2025 04:17 PM
@Vanguard I've added your post to an existing thread, as you have the same problem. See the post marked as Answer for a workaround.
If your ISP is Talk Talk then see the post marked as the answer for a possible solution.
Message posted on 25 Sep 2025 04:23 PM
							Re: Problems downloading programmes
https://helpforum.sky.com/t5/Sky/Sky-catchup-unusable/td-p/5095700
Message posted on 25 Sep 2025 04:28 PM
Is your broadband with TalkTalk by any chance?
Message posted on 25 Sep 2025 04:42 PM
Hi Wheat.
Thanks so much but I don't see DNS on my Network settings..
I have:
Connection to Broadband Router OK
Connection to On Demand OK
IP Address
DHCP
Network Name Talk Talk
Signal Strength
Security Type
I'm also with Talk Talk.
Message posted on 25 Sep 2025 04:52 PM
@Llwynypia try @oj01's post earlier in this thread for further help
Message posted on 25 Sep 2025 05:33 PM
I can't seem to navigate to see DNS and I have Sky + 😢
Message posted on 25 Sep 2025 05:36 PM
When you get to Network press to go down and you'll progress from there
Message posted on 25 Sep 2025 05:42 PM
I've pressed to go down and then pressed the green button. I then see:
Network Name
Security
Password
DHCP
Message posted on 25 Sep 2025 05:43 PM
I've got the same options
