12
Discussion topic: Sky cables work on sky q box but not sky+HD
This message was authored by pembs123 This message was authored by: pembs123
Hello,
We have moved into a house that has the dual sky cables and we have a sky+HD box we want to use for freesat. The sky+HD box says it is receiving no signal. However, when I tried my friends sky Q box, that worked just fine, is any about to point out why it works with the sky Q box but not the sky+HD?
Kind Regards,
Rob
This message was authored by jim8sky This message was authored by: jim8sky Answer
Re: Sky cables work on sky q box but not sky+HD
@pembs123
When you say the dish has dual cables do you mean it has two twin pairs of cables from it ie 4 cables total or do you mean there is one pair cable with two connectors to the dish.
If the former
where is the other paired twin cable going - check the box works on those and just switch the connectors other on the dish
If the latter
You will need to change the LNB in the dish back to a standard one or a Hybrid one.
Alternatively you could buy a freesat box that works with a sky Q LNB (wideband) which I understand from other poststhe newer 4K boxes will do.
