Discussion topic: Sky+ box won't record or show schedule
This message was authored by: MsZ
Hi, I replaced my sky+ box and it won't  record but will only download with adverts. And it will not show the week's schedule or programme information. If you try to record a programme it stops the signal. The old box was having problems recording too but wasn't as bad as this new one. Any thoughts or  advice would be very welcome. Thank you
Re: Sky+ box won't record or show schedule
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Avatar for MsZ
Level 0 icon
Thank you will give that a try.
