Discussion topic: Sky box not working
This message was authored by: TeriK
Sky box not working
That's it, it ain't working and sky won't answer
Re: Sky box not working
@TeriK wrote:
it ain't working
@TeriK
A lot more info needed for anyone to advise.
@TeriK  If you have a Sky+HD box Sky no longer support these.
Avatar for TeriK
Light on Sky+HD box not illuminating.
TV is ok but no Sky channels received.
Message says "weak or no signal"
Avatar for TeriK
Everything worked ok up to midday Friday
@TeriK  If your TV is showing "weak or no signal" that is your TV looking at the inbuilt tuner and can't see a Freeview signal
You need to scroll through the TV inputs to locate the one the Sky+HD box uses.
Avatar for TeriK
Sorted for now.
Thanks ever so much.
@GD1
Tagged in error.
You mean the power LED on the front panel? Check the fuse and try a different power socket. If neither resolves it, I'm afraid your Sky box has probably expired. You can't use a replacement Sky+ box, so you woud need to talk to Sky about upgrading.
@Daniel0210 wrote:
@GD1
Tagged in error.
Corrected 🙂
