Discussion topic: Sky box not working
This message was authored by: Farmerc78
Sky box not working
Sky box isn't working gone through reset and suggest need engineer as no satellite signal
Re: Sky box not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
