Discussion topic: Sky box not receiving signal
This message was authored by: Donna180
Sky remote information has worn off buttons so can't use that to help
sky box not receiving signal
sky account not recognised due to being over 13 years old
Re: Sky box not receiving signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
