Discussion topic: Sky box not initilising
This message was authored by: Lainey1960
No Channels For past few days
Re: Sky box not initilising
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
