Discussion topic: Sky + box keeps freezing.
This message was authored by: Wendywoo23
Shy + box keeping freezing 2-8 times. Day. I have run through all the suggested fixes on here several times now. Anyone any other ideas apart from throwing the flipping think out of the window....😤😤😤
Re: Sky + box keeps freezing.
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Though it sounds like the box is at the end of its life 😞
Avatar for Wendywoo23
Level 0 icon
Thank you, will try your suggestion
