Discussion topic: Sky + book a technican
This message was authored by: Jeffrey12
Bad weather in area , not all channels are working , ran a diagnostic on app but no  prompt fir me to book a engineer .
i need to book an engineer to come and check my services at no charge . Spoke to radia who advised me of this that the  L&B on dish not working , dish alignment
Re: Sky + book a technican
@Jeffrey12  unfortunately regardless of what you were told n the phone Sky no longer supports sky plus setups so won't supply engineer support
you would have source an independent contractor at your own expense  if you can't fix it yourself
@Jeffrey12
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £ 65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
@Jeffrey12
Do you have a Sky+ box or a Sky Q one ?
