Discussion topic: Sky TV not working
This message was authored by: Liebruti
Sky TV not working
My sky TV stopped working a short while ago.No reception.Anyone else having g this problem today?
Re: Sky TV not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Avatar for Liebruti
Thank you for your reply.It is working now.
