Discussion topic: Sky TV is not working
This message was authored by: Townie123
No sky connection
Re: Sky TV is not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
Avatar for Townie123
I am waiting for an engineer date earlier than July 25th
