Discussion topic: No satellite signal have followed all the steps need an engineer
This message was authored by: Annette96
I am going around in circles!   Need to book an engineer
Re: No satellite signal have followed all the steps need an engineer
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
