Discussion topic: Sky Signal
This message was authored by: Ohwhatthehell
Sky Signal
I have not had a Sky signal since last night (5/09/24) at 8.30 pm?
Re: Sky Signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Avatar for Ohwhatthehell
Re: Sky Signal
The message I get is your box is still initialising, please return in a short time to use this feature.  How can I get sky to check whether I am getting a signal or not?
Re: Sky Signal
If you still have menu access, press Services > Settings > Signal on your remote. The white part of all 4 bars should be at least half way across.
Re: Sky Signal
@Ohwhatthehell Did you get the bad storm last night? Have you tried rebooting your Sky box?
Re: Sky Signal
Yes we had a storm and I have rebooted the system a few times.
Re: Sky Signal
I guess the storm moved the dish slightly 😞
For your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Sky subscription
How do I unsubscribe from Sky and get my money back as they want to upgrade my system as the box is old and not supported and it will cost me £149.00 extra.  I am tired of Sky''s attitude
Re: Sky subscription
@Ohwhatthehell  What money do you think you are entitled to as you won't get anything back from monthly subscription costs
if you wish to cancel/downgrade choose an option on the link below (which includes a message service - not available in ROI) (just click on yes I need more help)
https://www.sky.com/help/articles/cancel-sky-tv#M1014
Note that if your within a minimum term (most Sky contracts have a minimum term of 18 months) for the service you wish to cancel you may not be able to
Also note you have to give the required relevant notice to cancel which is 31 days for tv and 14 days for broadband
Additional information on Broadband: If you are changing to Virgin or cancelling broadband totally you'll have to contact Sky This link should help
https://www.sky.com/help/articles/cancel-sky-broadband#M1014
If you are changing to another ISP who uses the Openreach infrastructure then join up with them and they should contact Sky on your behalf
If in ROI make sure the flag in bottom right hand corner is set to ROI and refresh the page before selecting an option
for reference cancellations are only confirmed once you have written email confirmation, also remember that if you are cancelling sky q or stream (where stream was ordered on or after 23/02/23) completely all equipment will need returning so make sure when sending back you obtain and keep very safe and indefinitely proof of postage, also note that billing continues as normal right upto and including last day of notice period and must be paid, any overpayment for days beyond termination date will be refunded within six weeks of termination date or you can call sky and they will refund within 3-5 working days once the credit is showing on your sky account
apparently best times to call are first thing in the morning 7am or last thing at night 9pm
You could get a local satellite installer to check your dish alignment for you?
Re: Sky Signal
Nothing. look like not signal at all, I will take ask someone to look at the sky dish on as it could have move a wee bit.
thanks
Re: Sky Signal
@Ohwhatthehell  Are you on minimum term or rolling Sky subscription contract?
Sky+ subscriptions just give access to to Sky subscription services ... it is your responsibility to ensure you have equipment capable of receiving those services🤔
