Discussion topic: Sky Pro
This message was authored by opl73 This message was authored by: opl73
Sky Pro
I cannot play a Sky Programme I have just recorded. It is showing it has recorded on the information, but when I try to play it, it plays it for 1 minutes and then it stops and shows a message on the screen 'end of programme' press BACK UP to return
I have tried a Sky Planner Rebuild, to no avail.
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky Pro
What's the duration of the recording shown as? It sounds as though the programme hasn't recorded correctly.
opl73
Re: Sky Pro
Hi, duration is 3 hours. Showing it has used 10.6%, but it is showing part record ; 1 min. I recorded it today at 4pm and it was still recording at 7:30pm...when it ended. That's when I tried to play it.
Re: Sky Pro
Looks like the recording has failed, then. If you highlight the failed recording in your Planner, the failure reason should be shown at the end of the programme synopsis on screen.
opl73
Re: Sky Pro
Cheers. Knew it was a longshot - gutted. 😞
On average, new discussions are replied to by our users within 100 minutes
