13 Jun 2022 01:01 PM
Last week, my Sky+ box started reporting an "issue with broadband connection".
At the same thing the other device plugged into the Sky Hub ethernet ports (a Tp-link wifi router) started having severe, intermittent connection issues. I believe there may be a fault with the ethernet ports. There is no problem with the Wifi.
Looking at the lights on the ethernet ports itself, each connected port has a steady amber light and a flashing green one. Is this as expected? Shouldn't the amber one be blinking if data is being transferred?
13 Jun 2022 01:07 PM
Have a read below the solid light indicates the speed of connection the flashing green one means data is being transferred
13 Jun 2022 01:09 PM
Ie your connection is gigabit and data is transferring
13 Jun 2022 01:11 PM
What model of tp link router do you have?
thanks @cookiemonsteruk . So it looks like the ports believe data is going back and forth, but according the Sky+ box there is an issue.
In the Network Settings of the Sky+ box it is also all reported OK.
What could be preventing the Sky Hub and Sky + box from communicating?
13 Jun 2022 01:12 PM
@cookiemonsteruk I have the TP link Archer A-7 (AC1750)
13 Jun 2022 01:16 PM
Take a look at the tp link settings ie if operating mode is wifi router switch to access point mode
13 Jun 2022 01:39 PM
13 Jun 2022 01:44 PM
Not too sure. If the tp is set to wifi router that introduces double nat. Also if sky q is anything to go by it may have a preference to a direct ethernet connection to be hub. I will transfer to sky+ hd forum as i believe its the lan connection between sky + hd and the tp
13 Jun 2022 01:55 PM
thanks, @cookiemonsteruk
I think there may have been a misunderstanding, The Sky+ box is connected via ethernet to the Sky Hub. NOT the TPLink. The TP Link is completely off the network now.
On average, new discussions are replied to by our users within 100 minutes
