4
This discussion topic has been answered Discussion topic: Sky+Hd LNB issues
This message was authored by: skyqkid
Sky+Hd LNB issues
My daughters Sky has been intermittent depending the weather conditions.
She says the system is of approx 15/20 yrs old.
So my first thought was the LNB, its direction is approx 15O/155 degs.
Can anyone ID the LNB and suggest a replacement.
This message was authored by: Mark39 Answer
Re: Sky+Hd LNB issues
Yes, to enable two contemporaneous recordings, you'd need two cables from the LNB.
Avatar for skyqkid
Level 3 icon
If the LNB cannot be identified in the photo.
Could anyone suggest a 2wire LNB for Sky+ to replace the existing or what type should be looked at ie: Universal/Wideband etc.
thanks
For Sky+ you just need a standard LNB, not wideband. It's the fitting to match the dish that will need consideration.
Avatar for skyqkid
Level 3 icon
As it has 2 wires, would that be a standard twin lnb to allow 2 recordings
thanks
