Discussion topic: Sky + HD volume not working properly
This message was authored by: SamuelQuartey
My sky+ volume is not working properly
Re: Sky + HD volume not working properly
Can you elaborate as you have not given us much to go on 😞
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for SamuelQuartey
While the TV is on the volume goes down gradually after successive volume turn up/down. And even at 24 the volume is still low and l can't hear the sound from the TV.
Are you sure this isn't a problem with your TV as it might not be the Sky box at fault.
