Discussion topic: Sky+HD remote control LG TV CODE
This message was authored by: michaelH0903
can anyone advise what the remote control code number is for the Sky+HD remote,as ive just changed my tv to a an LG 43UT73006LA model 2024 thanks michael
Re: Sky+HD remote control LG TV CODE
Try: 1293 or 0206
Avatar for michaelH0903
Level 2 icon
tks annie i will try both codes  michael
Level 2 icon
ive tried about twelve including,the ones you mentioned and no luck?  Michael
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
