5
This discussion topic has been answered Discussion topic: Sky+HD box not recording
This message was authored by: CMEl
My Sky box is no longer recording despite numerous reboots.
How do I get a new sky box? I can't get skyQ as the access team can't get on to my roof to  change the dish receiver.
This message was authored by: nigea99 Answer
Re: Sky+HD box not recording
hi @CMEl
I believe often people find SKY HD boxes on ebay
hi @CMEl
Try a Planner rebuild:
For Sky Plus HD boxes (DRX890/DRX895) with the latest software try the following instructions:
• Press SERVICES on your Sky remote control
• Go to Help
• Select Sky+ Rebuild
• Press SELECT (this will start the rebuild)
If the above does not work try the following (Note: the first 5 steps are better done whilst looking at the remote control as the feedback on screen can be confusing):
• Press 0 (very old boxes may need you to press 4 instead)
• Press 0
• Press 1
• Press SELECT (You should now be in the hidden menu)
• Press 7 (Sky+ Rebuild)
• Press SELECT (An on-screen message will be displayed)
The above and so much more can be found in my Sky Plus F⋅A⋅Q
Avatar for CMEl
Many thanks, I'll try that.
This message was authored by: NilemThakrar
I have turned Sky box on & of still not recording
Tried @Annie+UK's suggestion?
