Discussion topic: Sky+HD box Frozen
Message posted on 03 Oct 2024 02:10 PM
Sky+HD box Frozen
My Sky+HD box has frozen and does not respond to the remote. I have tried the online help using the backup button but no lights appear and box still frozen/dead. Have no managed to contact anyone (person) at sky to resolve. Any help / advice welcomed
Message posted on 03 Oct 2024 02:12 PM
Re: Sky+HD box Frozen
Try leaving the box off at the plug for 5 minutes or so, before restarting by pressing and holding the backup button (on the box, not the remote), while switching on again at the plug. Keep it pressed until the lights on the front panel flash.
Message posted on 03 Oct 2024 02:14 PM - last edited: 03 Oct 2024 02:17 PM
Message posted on 03 Oct 2024 02:40 PM
Followed your suggestion, still no lights on the front panel.
Message posted on 03 Oct 2024 02:57 PM
I'm afraid the box has expired, then, and will need replacing. There are no new Sky+HD boxes, but you can buy a used replacement from ebay etc. Look for a DRX890 or DRX895 model. Or you could upgrade to Sky Q or Stream.
Message posted on 03 Oct 2024 03:08 PM
Thanks Mark39 - I was afraid that was goi ng to be the answer - lots of lost recordings then!!!
Message posted on 03 Oct 2024 03:17 PM
'Fraid so. You might be able to find some of them on On Demand.
Message posted on 03 Oct 2024 04:16 PM
@RichardH2 wrote:Thanks Mark39 - I was afraid that was goi ng to be the answer - lots of lost recordings then!!!
All recording are eventually lost ... unless transferred .... and transferred ... and ever retransfered😉
