10
This discussion topic has been answered Discussion topic: Sky HD+ TV Guide error
This message was authored by: MikeP07
Sky HD+ TV Guide
Keeps displaying the meaasge:
..no listings available
even on the guide for today. Will no longer display any listing beyond 4 days.
This message was authored by: Annie+UK Answer
Re: Sky HD+ TV Guide error
Try a Planner Rebuild, this will reboot the box
See question Q02 in my Sky Plus F⋅A⋅Q
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Check your signal strengths - Services> Settings> Signal.  The white part of all 4 bars should be at least half way across.
Avatar for MikeP07
Hi,
Thanks fot quick reply. Signal strength/quality is 80/90%
@MikeP07 wrote:
Hi,
Is that BOTH inputs?
Avatar for MikeP07
Signal 2 strength is c70%
Equal c90% on both for quality.
Avatar for MikeP07
Told by Sky that my device no longer recieves software updates. Will that fix still work?
Planner rebuild has nothng to do with the software on the box 🙂
Avatar for MikeP07
Yay!
That worked!
Thank you!
Sky no longer support Sky+ HD boxes ... so that's their standard answer to almost any question about Sky+ HD issues😟
