Discussion topic: Sky + HD Box - This Viewing Card is not Authorised
This message was authored by: Sky_Moose1
Hi, I have a Sky + HD box and tonight had the message "This Viewing Card is not Authorised" whenever I tried to access most of the Sky channels. I could access other channels such as BBC, ITV, Channel 4 and, for some reason, Sky Arts and Sky news.
I haven't watched TV for a few days but it was ok earlier this week.
I haven't requested a new viewing card and am not upgrading to Sky Q. Everything on my account is as expected with no updates or messages over the past few weeks. All payments are up to date and I haven't received an Email.
Is it possible that Sky have dsconnected me for some reason or is it a problem with my viewing card all of a sudden?
I have tried switching the box off and on but that didn't help
This is also happening with some of the programs I had already recorded.
I'll ring them on Monday, but perhaps someone on here has had a similar issue for no apparent reason.
Is there anything else I can try that may work but won't mess things up even more?
Also, I can't actually see where the card is inserted in the Sky + Hd box. Online help says it's on the right of the box, but I've had a look and it doesn't seem to be where the YouTube video says it is! So I can't even check the viewing card (not that I'd know what to look for anyway)
Anyway, if anyone could shed any light on any of the above it would be appreciated.
Re: Sky + HD Box - This Viewing Card is not Authorised
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Sky_Moose1
Hi, thanks for the reply. I did try a New Install as per the instructions, but it didn't seem to make a difference. Still getting the same "This Viewing Card in not Authorised" message.
I'll try ringing them and see if they can sort it at their end.
I still cannot see where the viewing card is actually inserted. Bizarre, I've looked all over the box and there doesn't seem to be anywhere obvious.
My Sky Plus FAQ Q37 🙂
Ah yes, thanks, that was well hidden!   🙂
Would there be any point in me taking out the viewing card and sticking it in again? I woudn't really know what I was looking for.
If I did that, should I shut down the Sky box or can I do it while the TV is still on?
You can pull out the card and put it in again without turning anything off, I doubt it'll help but it'll do no harm
Thanks, just tried that, but as expected it made no difference. I'll probbaly give them a ring if there are no more attempt options at my end.
Good luck
