Discussion topic: There’s no power on the sky box, no lights anywhere , so when I press select for it to come on nothi
This message was authored by: JackieE26
Message posted on 27 Jul 2024 01:39 PM
There's no power coming from the sky box. It won't switch on
Find out more
Message posted on 27 Jul 2024 01:44 PM
Re: There’s no power on the sky box, no lights anywhere , so when I press select for it to come on n
Check the easy things first - is the power cable still securely plugged into the socket at the back of the box?
Check the fuse in the plug, and try another device (lamp?) in the mains socket to make sure the power from the mains socket is ok.
Find out more
Message posted on 27 Jul 2024 01:51 PM
Plug fuse?
