Discussion topic: Sky Channel 118 not working
This message was authored by: RB8293
Sky channel 118 isn't working. All other channels are fine. Does anyone have a similar problem? Thank you
Re: Sky Channel 118 not working
"isn't working", how?
Avatar for RB8293
No Signal Annie
"No signal" or "No SATELLITE signal"?
Avatar for RB8293
Sorry Annie... satellite signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
Avatar for RB8293
Annie
Thank you so much for your help.. I think I'll need to call a satellite/ariel company as you suggest.
Thanks again
