Discussion topic: Sky Boxes
This message was authored by: KCSky2
Sky Boxes
I have 2 Sky HD+ boxes which are no longer required as I have cancelled Sky Tv subscription
What do I do with these boxes?  Do you want them back or do I take them to the tip?
Re: Sky Boxes
@KCSky2
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Sky+ and Sky+HD boxes are yours to do with what you like (obviously disposing of them sensibly).
Re: Sky Boxes
Rather than take them to the tip you should really consider getting them recycled. Electronic devices can be stripped down and certain parts re-used or melted down. If you don't have a small electrical devices recycling point near you then you can send them via Freepost to Sky for recycling. You can print off a label here:
https://www.sky.com/help/articles/recycle-sky-equipment
