Discussion topic: Signal
This message was authored by: TTR125
Signal
I have a number of channels that have started having no satellite signal available - can I retune or does the dish need moving ?
Re: Signal
@TTR125
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream. If you upgrade to Sky Q any dish, LNB or cable issues would be sorted out f.o.c as part of the process.
▪️I AM NOT A SKY EMPLOYEE ▪️
