Discussion topic: Signal issue
This message was authored by: DQANDRE
Signal issue
All my sky+ HD boxes lost signal simultaneously. Signal strength is zero across 5 boxes. This seems to point to a failed LNB. I have a private dish, not communal.  Need help
Re: Signal issue
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
Annie..........    Note: These Sky help forums are primarily for customer-to-customer help
