Discussion topic: Sky sports HD
Message posted on 04 Jan 2026 07:08 PM
Sky sports HD
I pay for HD
Sky sports isn't showing HD in the top right hand corner of the screen. I have checked and it should be
Message posted on 04 Jan 2026 07:12 PM - last edited: 04 Jan 2026 07:15 PM
Re: Sky sports HD
@di37 The channel on screen dogs haven't shown the letters hd for years (any information online to suggest otherwise is now long out of date)
the reason is sky sports is now hd as standard so there is no longer any need to differentiate the difference on screen
if you look at the epg and the search and scan banner it shows the letters hd on there
Message posted on 04 Jan 2026 07:19 PM
Re: Sky sports HD
Thank you.
My son has HD exact same tv shown under the Sky Sports Main Event on the screen
Message posted on 04 Jan 2026 07:48 PM
Re: Sky sports HD
@di37 wrote:Thank you.
How is he watching it? on Sky the "HD" label hasn't been included in the channel logos for about 4 or 5 years.
Message posted on 04 Jan 2026 07:52 PM
Re: Sky sports HD
@di37 There is a sky sports main event uhd channel which does display a dog but that only appears on a main sky Q box so if there is a uhd subscription in the household he may be watching that channel
but be aware you have posted on the sky plus board which doesn't support uhd content
are you and son in same house and do you have Q or plus hardware
