5
Discussion topic: Searching on Sky Box Sets A to Z
This message was authored by Bobby++B This message was authored by: Bobby++B
Hello, I wonder if anyone can help with this.  I used to be able to go to the Sky Box Sets, then under Genre there was an A to Z option where I could search for shows, in particular the new Star Trek series on Paramount +.  For some reason I no longer have the search box at the top of the screen here?  Has this been removed for some reason?  When I am on the screen for the A to Z is starts with all the shows begining with the number 1, so it would probably take me about 3 weeks to scroll down to the letter 'S'.  Any help greatly appreciated.
Thanks,
Bobby++B
This message was authored by Bobby++B This message was authored by: Bobby++B Answer
Re: Searching on Sky Box Sets A to Z
@oj01 , I have looked under sky cinema but that only showed movies not series/shows.  So had a look under Catch up......
Yes!!! it's there, thank you ever so much, this has been litterally driving me crazy. 🙂
I can't see the search option either but as I have never used it I can't say if it has been removed. Another possible way to do this is to select Channels instead of Browser Genres as there is a search facility there.
Bobby++B
Thanks caesarome but when I go to Channels, Paramount + isn't listed even though I can see Paramount + on a couple of the shows that appear with a number in the name on the first page of the A to Z.
This message was authored by oj01 This message was authored by: oj01
@Bobby++B I think you are correct here as I believe that you used to be able to Search within the A-Z section.
However, you should be able to find Paramount + content within both the Catch Up Tile and Sky Cinema Tile
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Staying on Sky+HD
Bobby++B
This message was authored by Dave+on+Sky This message was authored by: Dave+on+Sky
I checked Sky TV during January 2023.  Unfortunately the A-Z search only works for channels, it does not work at the top level in Sky Box Sets.  Unless you know what channel a progrmme was broadcast under you are left with a manual scroll through every programme alphabetically which would take so long it makes Sky Box Sets almost useless.  What Sky need to do is simply re-introduce the function to search for all progarmmes at the top level in Sky Box Sets.  If they can set up the Sky+ HD box for that search by channels they should have the expertise to set it up for Sky Box Sets.  Come on Sky.  Thanks.
On average, new discussions are replied to by our users within 100 minutes
