Discussion topic: Recording not working
This message was authored by: Tiqvah
My SKY + box and controller seem to be working fine except when I try to record a new program the little red r does not appear and new programs do not record.  Programs which I had previously recorded I  continue to get the series recordings.
Any ideas as to what the problem is and how to solve it. Thanks Tiqvah
Re: Recording not working
Try a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something.
