Discussion topic: Satellite signal
This message was authored by: Burcott5
Satellite signal
My viewing is constantly disrupted with the message satellite signal not working.  This clears if I cancel any recordings currently running
Re: Satellite signal
Sounds like one of the dish inputs is the issue
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
